║ Add to Siri
Siri shortcuts will be available soon. You can add a custom phrase, ask Siri to tell eWeLink to run a task (Tap to run, manual scene).
➤Example:
Set a manual scene: if tap to perform, then turn on Light 1, Light 2, Light 3......
Then add it to Siri.
When you say: Hey Siri, I’m home, eWeLink will run the “I’m home’” scene.
# For iOS 12 and early versions, the process is basically the same, you can record your custom phrase instead of typing.
║ Alexa: Plug and play
Part of eWeLink devices is now certified as Alexa Humans Eligible Products.
➤ As soon as the device is power on, it will show up in both Alexa and eWeLink app automatically, without repeating the old pairing procedure.
# eWeLink account linking with Alexa is required.
