Skip to main content
How to create scenes with multiple conditions in eWeLink app
11 comments
  • ivanildomaiajr
    Hi, I need to delay in "if conditions field", because if the door to continue open in the upper time 15s, then execute the action X. Help me please.
    0
  • rondirks
    I tried scenes with multiple conditions excactly like the sample mentioned above, but it didn't work. then I found out i should have ewelink V4.4, I still have V4.21.0 and thus I checked for updates at the play store but even there it says V4.21.0. so the question is: when will V4.4 be released?!
    0
  • Zaydoon Al Shakir
    Hi admin Zendesk want to chat with you online can you do that
    0
  • rondirks
    and how do you want to do that.
    By the way, I had a few more threads waiting for updates in the ewelink app feedback section, and all of them are gone. And I never got a reply on those. just 1, we will be looking into it
    0
  • rondirks
    so what is the problem!!? because the above explanation of scenes with multiple conditions still doesn't work, at least not with me
    0
  • rondirks
    I can't help you because I have given up on this. I tried to contact ewelink but I got no response.
    maybe you have more luck at facebook, search for https://www.facebook.com/groups/ewelinkandsonoff/. maybe there is somebody who can help you there
    0
  • Graham Horn
    I must say that I find the functionality in the scenes very limited... I can set a condition to trigger and auto scene when a device is manually turned on let's say, but why can't I trigger the scene when the device is turned on from within another scene?
    0
  • Graham Horn
    Another question. Why can't there be conditions for manual scenes? For example, I might not want a manual scene to be able to run when we are having a power outage and running off battery/inverter backup.
    0
  • rondirks
    chat, ok, just tel me how
    -1
  • Zaydoon Al Shakir
    Hi
    There is no need just let me explain my problem
    -1
  • Zaydoon Al Shakir
    And how can make this scene because I cannot make the manual scene
    Execute other scenes
    When creating scenes, you can now add ‘Smart Scenes’ as an action. When you select ‘Smart Scenes’ as action, you will be given two options, respectively ‘Perform manual scene’ and ‘Enable/Disable auto scene’.
    The name of each action is quite self-explanatory.
    When you select an auto scene, this action will enable or disable the selected scene. As for a manual scene, this action will execute the manual scene as if you are tapping on it.
    What can this be used for?
    Let’s say you already have a manual scene named ‘I am home’ which you tap and turn on all the devices in your home. (You may read the other article about the scene feature, 'How to create Scenes', to check how you can set a one-condition scene)  In the past, you had to tap on the scene to trigger it. With the updated scene feature, you can add much more complicated rules as its conditions. When sunset and the motion sensor detects motion at the front door, automatically execute all the actions in the “I am home” scene.
    -2
Powered by Zendesk
