New Device supported by eWeLink:
Smart Doorbell
Even when you are away from home, you can still receive push notification and view history records to know about the visiting situation.
Moreover, the smart doorbell support adds a camera to view(Bind with eWeLink IoT camera or turn your old phone into an IP camera), so when the doorbell ring, you will know who has come to your house.
Smart Door Sensor
Door Sensor can detect whether the door is opened and will notify you by sending a message to your phone. The eWeLink supported door sensor does not require gateway/hub, simply add it to eWeLink app. Moreover, you can combine it with the Scene function to trigger other devices. For example, when you return home at 8:00 pm on workdays, as soon as the door is open, the lights and fan of the living room will be turned on automatically.
It’s very easy to install anywhere with a double-side tape, create a secure environment for your house, office, etc.
New pairing method:
The Door Sensor uses Bluetooth Connecting Mode.
Press and hold the button of the device for 5s, the app will search for Bluetooth device automatically, select Bluetooth device and WiFi, enter WiFi password, follow the instruction to complete the connecting process.
