Floor Plan helps you create a visual map of your home, organize smart devices by room, and control them directly from your Home Map.
With eWeLink WEB V3.26.0, Prime plan subscribers creating floor plans is now easier than ever. New built-in guidance, visual tool demonstrations, and a simplized editing experience help you get started with confidence and spend less time switching between tools.
While these guides provide assistance throughout the creation process, this article offers a complete walkthrough of the entire workflow—from creating your first floor plan to organizing devices and managing your Home Map.
Whether you’re creating a simple apartment layout or a multi-floor home, the steps below will help you build your floor plan more efficiently.
Create a New Floor Plan
Before you start drawing, you’ll first need to create a floor plan for your Home.
Open the Floor Plan page and click Get Started. Then select the Home where you’d like to create your floor plan.
Each floor plan belongs to a specific Home, allowing you to organize rooms, devices, and floors separately.
Configure Your Drawing Preferences
Before you start drawing, it’s worth taking a moment to review the available drawing settings. These options can help make the editing experience more comfortable and ensure your floor plan matches your preferred style and measurement system.
Customize the Drawing Appearance
The editing workspace can be customized to suit your preferences:
- Canvas Background – Choose a background style that makes your layout easier to view.
- Line Color – Customize the color of walls and layout elements for better visibility.
- Snap Alignment – Enable or disable automatic snapping when drawing or positioning elements. This can help align rooms and structural elements more precisely when building your layout.
These settings only affect the editing experience and can be adjusted at any time.
Choose Your Measurement Unit
Floor Plan supports both metric and imperial units.
Whether you’re more comfortable working with meters (m) or feet (ft) , selecting your preferred unit before drawing can help create a floor plan that better matches your home’s dimensions.
The measurement unit can be changed at any time while editing.
Step 1. Outline Your Home
Every floor plan starts with the structure of your home.
Using walls, partitions, and fences, you can create the shape of your living space and define different areas within it. There is no single correct way to draw your layout. The best approach depends on whether you prefer to start with the overall structure or individual rooms.
Drawing Methods
Method 1: Outline → Rooms
Draw the outer boundary of your home first, then use partitioning tools to divide it into rooms.
Method 2: Rooms → Layout
Draw rooms individually first, then move them to assemble the complete structure.
Helpful Drawing Tools
While drawing, several tools can help improve accuracy and efficiency:
- Length Input – Define wall lengths more precisely while drawing.
- Angle Alignment – Hold Shift to maintain the original angle when adjusting walls.
- Undo / Redo – Use Ctrl + Z and Ctrl + Y to quickly revert or restore changes.
- Finish Drawing – Double-click or return to the starting point to complete an enclosed area.
Once enclosed areas have been created, your home structure is ready for the next stage.
Step 2. Add Structural Elements
After the basic layout is complete, you can switch to the Shapes tab to begin adding the architectural details that make your floor plan easier to understand.
You can enrich your floor plan with:
- Doors – Represent entrances and room connections throughout the layout.
- Windows – Reflect the actual structure of your home and improve visual accuracy.
- Columns – Add round or square columns and adjust them as needed.
- Stairs – Represent connections between different floors.
Once placed, they can be resized, rotated, duplicated, or removed at any time. Doors and windows automatically align with nearby walls, helping you build your floor plan more efficiently.
At this stage, the overall structure of your home should closely match its real-world layout.
Step 3. Add Furniture and Appliances
With the structure in place, you can start turning your floor plan into a more complete representation of your home.
Switch to the Objects tab to customize each area and add the details that make your Home Map easier to recognize at a glance.
Furnish Your Home
Furniture, appliances, and decorative objects can be added to reflect the actual layout of your living space.
Whether you’re placing a sofa in the living room, a refrigerator in the kitchen, or decorative items throughout the home, these objects help create a more realistic and intuitive Home Map.
Adjust Objects as Needed
Once placed, objects remain fully editable.
You can move, rotate, or resize furniture and appliances at any time, allowing you to refine the layout as your home evolves.
When all rooms, furniture, and appliances have been added, the interior view of your home is complete and ready for device placement.
Step 4. Assign Devices to Rooms
With the layout complete, switch to the Device tab to connect your floor plan with your smart devices.
Match Areas with Existing Rooms
For each area on the map, simply select the corresponding room, such as Living Room, Bedroom, Kitchen, or Bathroom.
Rooms are based on the room structure already configured in your Home. If needed, new room can be created and room names can be modified from the Home page before building your floor plan.
Room colors can also be customized to make different areas easier to distinguish.
Let Devices Follow Their Rooms
Devices are automatically grouped under the rooms they were assigned to when added to your Home.
Once a room has been placed on the map, devices belonging to that room will appear in their corresponding areas.
For example:
- Bathroom → Bathroom devices
- Living Room → Living Room devices
- Bedroom → Bedroom devices
Step 5. Organize Devices on Your Home Map
This is where your floor plan becomes an interactive smart home dashboard. Once rooms have been assigned, you can begin arranging devices to reflect their real-world locations.
You can also customize how devices appear on the map:
- Place Devices – Drag devices into the rooms where they physically exist.
- Resize Device Icons – Adjust icon sizes to improve visibility.
- Move Device Icons – Position devices more accurately within each room.
- Hide Devices – Remove device icons from the map without removing them from the Home. Hidden devices will be collected in the “Hidden Icons” list, where they can be restored at any time.
Devices in the “Unassigned” list can be placed by dragging their icons to any area on the map.
These adjustments help create a cleaner and more intuitive Home Map while keeping important devices easy to locate and control.
Save Your Home Map
Once rooms and devices have been arranged to your liking, click Save to complete your floor plan.
View and Manage Your Home Map
Once saved, your floor plan becomes an interactive smart home dashboard. Instead of navigating through long device lists, you can view your home visually and interact with devices exactly where they belong.
From the Home Map, you can:
- Device Status Monitoring & Device Control – View real-time device status, including On, Off, and Offline states.
- Floor Switching – Quickly switch between floors using the floor selector.
- Floor Management – The bottom-left corner of the canvas also supports quick floor switching. Click the button in the bottom-left corner to switch to the multi-floor view, making it easy to see your floor plans and device locations at a glance.
- Floor Plan Management – Edit existing floor plans or create new ones for other Homes.
With your Home Map in place, managing your smart home becomes more visual, intuitive, and efficient. As your home evolves, you can update your floor plan at any time to keep devices, rooms, and layouts perfectly organized.
