Edit multiple timers simultaneously
Summertime will come soon! This year, Daylight Saving Time begins on Sunday, March 14, 2021, at 2:00 A.M. There are over 70 countries in the world observing DST. For some countries like Australia and the USA, some states observe DST, while some not. Is your country or area still applying DST to make better use of daylight? If so, please make sure you set the clock forward one hour in advance. Of course, thanks to the Internet, your smartphone will do this manual job for you.
As the clock is set forward 1 hour, your schedules and timers for your eWeLink Support devices will require adjustment as well. It is worth mentioning that time-based scenes also require changing. We understand that it is annoying to change so many schedules and timers altogether. This is where the Edit Timers feature comes in very handy. You can select multiple timers at the same time to edit them all at the same time.
Follow the steps below to adjust your timers when summertime comes.
- Open eWeLink app, tap Profile and tap the gear icon on the top-right of the page.
- Tap Edit Timers.
- Select the type of timers to change.
4. Select all the timers to change, and tap Next.
5. Set the action for the selected timers to take, and tap Save.
6. As soon as you see the changes are done, tap OK.
In history, Daylight Saving Time was used to save energy and make better use of daylights. However, with the development of modern technology, people begin to find this method ineffectual. As a result, more and more countries start to consider abolishing DST in the future. That’s also one of the main reasons why our solution to DST is to edit multiple timers altogether instead of changing the local time simply.
