What's New in V4.11
Another month has come and gone, we are so excited that eWeLink V4.11 is coming. This month, we have added some useful new features and optimized the following functions.
SONOFF TH
1. Effective Period
The auto control of SONOFF TH series could only be set based on temperature or humidity all time, all day in the past, but real life situations are far more complex. In response to the long time feature request from our users, eWeLink V4.11 adds the effective period feature that can turn on or off the device according to different time of day along with temperature and humidity. Our auto control allows you to set up to 6 different effective periods , to cater to your flexible needs in different conditions.
Step 1: Open eWeLink app, tap TH device and tap Auto
Step 2: On the top right tap+to add effective periods
Step 3: Choose Temp. or Humidity.
Step 4: Set specific values and effective time, tap Save
2. Change WiFi
Now Sonoff TH support the change WiFi feature. It is very useful if you want to change your home router or network information (such as WiFi SSID or password). Click here to learn more about WiFi settings.
RF Bridge
1.Remote buttons used as triggers in scene
Scene is one of users’ favorite featuresAbove all the requests about the scene feature, one of the most expected features is to use the remote buttons in RF bridge as a condition/trigger to create scenes. From V4.11, you can add the remote buttons of an RF Bridge as a condition of any scene. Originally, It can only be used as actions. Such an update allows for more innovative usage of RF bridge and better application of home automation.
Step 1: Open eWeLink app, tap Scene, and tap+
Step 2: Tap + Add, you can add trigger condition
Step 3: Select Smart device
Step 4: Select RF Bridge
Step 5: Select your Remote, tap Save
2. Change WiFi
Now RF Bridge supports the Change WiFi feature that allows you to change WiFi info without re-pairing your RF bridge. It is very useful if you want to change your home router or network information (such as WiFi SSID or password). Click here to learn more about WiFi settings.
3. Support for LAN mode
The LAN feature lets you continue to use your RF bridge or turn on or turn off its network indicator without internet connection. This means your RF bridge will be able to keep guarding your home security even without internet connection. Also, the remotes you learned remain control over your 433 devices.
To celebrate this new version, we will hold an in-app giveaway for 5 RF bridges. Click here to see how to enter to win a free RF bridge. All you need to do is answer some very simple questions.
5 comments
Unfortunately don't have effective period option in the iOS app (ver 4.11) . And I was really looking forward to it the version release.
@Istvan Szabo
Please note that your SONOFF TH should also have the firmware version V3.5.0 or above.
Ahh, ok, but the app says 3.4.1 is the latest firmware version for TH10.
Firmwares are rolled out batch by batch. It is possible that it is not your turn yet.
OK. Thank you. I wait.... :)
