How to Connect Philips Hue Bridge to eWeLink?
Philips Hue (Signify) has introduced Matter support for its Hue Bridges, enabling seamless integration between Hue Lights and eWeLink locally. This guide will walk you through the process of pairing your Hue lights with the eWeLink ecosystem via Matter.
⚠️ Prerequisites: Before you begin, ensure that you have the following:
- Philips Hue Bridge (latest firmware)
- Philips Hue App (latest)
- eWeLink app (V5.4 or above)
- NSPanel Pro (firmware V3 or above)
Getting Started
If you are new to Philips Hue, please refer to the official guide for the initial setup. The Hue app would also guide you on this. After a successful setup, your Hue Bridge should have three steady lights on. You will then be prompted to upgrade your Hue to the latest firmware, which enables Matter-related features for your Hue system. For more information on the firmware upgrade, please consult this official guide.
⚠️ Important: Ensure that your Hue Bridge has been upgraded and that your phone, Hue Bridge, and NSPanel Pro are all connected to the same local network.
Pairing Hue Lights with eWeLink
- Open the Hue app and navigate to the Settings tab.
- Tap on “Smart Home” and select “Other apps” (Matter) from the available options. If already paired with some third-party platforms, you will see a “+” button on the top right corner that you can tap for the following straps instead.
- The app will display information about what data will be shared via Matter. Tap “Next” to obtain a pairing code.
- Tap the small icon next to the code and proceed to the eWeLink app.
- Launch the eWeLink app and tap the “+” button in the top-right corner.
- Select “Scan” from the available options.
- On the code-scan page, tap “No available QR code, add manually.”
- Paste the pairing code obtained from the Hue app into the input field and tap “Next.”
- The eWeLink app will check the status of your network and Matter Hub. Once everything is verified, the bridge will be added to your eWeLink ecosystem.
- The eWeLink app will prompt you to rename the bridge and its sub-devices and assign them to a room. If you skip this step, you can always rearrange them later.
Congratulations! Your Hue devices are now ready to be controlled within the eWeLink platform.
Stay Connected with eWeLink
Forum: eWeLink Forum
Website: https://ewelink.cc/
