Control your devices with Siri in eWeLink app
The iOS version of eWeLink V4.3 has been available in the app store. The highlight of this version is the long-expected Siri shortcut feature. With a few simple steps, you will be able to control all the eWeLink supported smart devices with your iPhone or iPad.
How to set up
Create a manual sceneA manual scene is required to be added to Siri shortcut. Follow the steps to create a manual scene.
a) Tap 'add' in scene tap. b) Select 'Tap to perform' as the condition.
c) Set up the action of the scene such as turning on a lamp. Select 'Lamp' and 'ON'.
d) Save the scene and name it 'Turn on lamp'.
Add the manual scene to Siri ShortcutNow that you have created a manual scene, you need to add it to Siri shortcut. Follow the steps below.
a) Tap 'Add to Siri' on the top of the scene page. b) The next Siri shortcut page will show you the list of all manual scenes. Select the scene you just set.
c) Change the voice command as you wish and tap 'Add to Siri'.
Say 'Hey Siri, turn on the lamp' to your iPhoneYou are all set now. Say the preset voice command to your iPhone or iPad, and your manual scene will execute accordingly. In this example, you can say 'Hey Siri, turn on the lamp'.
