Descifra los códigos de falla de emparejamiento
Cuando el emparejamiento falla, los usuarios a veces pueden encontrar un código de error como "6101" en la pantalla junto al mensaje de error "fallo al emparejamiento". Qué significa eso? Profundicemos en los códigos de error y descifremos los códigos de falla de emparejamiento.
eWeLink app supports a variety of types of devices. The first thing you do before you can control a newly purchased product is pairing. Different devices allow diversified pairing methods. In summary, there are four most common pairing methods. They are ‘Quick Pairing’, ‘Compatible Pairing’, ‘QR scanning’, and ‘Bluetooth Pairing’. Due to the different mechanisms of each pairing method, errors are likely to happen anywhere. For your convenience, eWeLink app has specified the error code on the page of pairing failure. Error codes are categorized according to the pairing method. Quick Pairing Compatible Pairing QR scanning Pairing Bluetooth Pairing
Quick Pairing
The error codes for quicking pairing starts with the two digits ‘61’. 6101/6106/6107 Router settings These error codes mean that eWeLink app cannot find the devices or cannot assign IP addresses to the devices. To fix them, enable DHCP. 6102/6103/6104 Communication error Failed to receive the required data or device is not responding in the process of searching for, registering, or connecting the device. The solution to this type of error is to try again. If the pairing fails again, please try again with a personal mobile hotspot to test the WiFi functionality of the device. 6105 Timeout The app fails to find any devices within 3 minutes. Check if the device is still blinking twice and pauses repeatedly. If not, it has quitted quick pairing mode. Please try again. 6108 Unknown error Please submit feedback in eWeLink app if this error continues to occur.
Compatible Pairing
The first two numbers ‘62’ means you are trying to pair the devices in the compatible pairing mode. Compatible pairing mode is the method for you to manually connect to a WiFi hotspot generated by the device to tell the device which WiFi SSID and password could be used to connect to eWeLink servers. 6201 Device hotspot failure The app cannot acquire the SSID of the device. Power off the device, set the device in compatible pairing mode again, and pair again. 6202/6203/6204 Communication error The app fails to connect device hotspot, cannot receive device information or the device is not responding. Please try again. 6205 Failed to switch to home WiFi Please check if you have given the required permission to eWeLink app. Reboot your phone and try again. 6206/6207 Server error These errors happen when the app fails to register the devices or there is no response from the server. Please submit feedback in eWeLink app and wait for eWeLink to email you about the recovery time. 6208 Timeout The app fails to find any devices within 3 minutes. Check if the device is still blinking quickly constantly. If not, it has quitted compatible pairing mode. Please try again
QR scanning Pairing(SoftAP)
The QR scanning method applies softAP technology which connects to the access point generated by the device by scanning its QR code. It is similar to compatible pairing mode, so it also starts with the two numbers ‘62’. 6210/6211/6212 Communication error When the app is communicating with the device, the device cannot connect the access point of the device, cannot get device information or the device is not responding. Please try again. 6213 Failed to switch to home WiFi The app fails to connect the phone back to your home WiFi. Please check if you have given all required permissions to eWeLink app. Reboot your phone and try again. 6214/6215 Server error The app fails to register the device or get the device type. Please submit feedback in eWeLink app with the device ID and a screenshot of the error code and wait for eWeLink to email you about the recovery time. 6217 Device hotspot failure The app cannot acquire the SSID of the device. Power off the device, scan its QR code again, and pair again.
Bluetooth Pairing
If an error code starts with ‘63’, then you are trying to pair a device in the Bluetooth pairing mode. Please make sure that your device supports Bluetooth pairing before you use this method. 6301 Scanning failed 6302 The app fails to connect the Bluetooth device. 6303 The app fails to send WiFi info to the device. 6304 The Bluetooth device fails to connect to WiFi. 6305 The app cannot get device information. 6306 Failed to register the device. 6307 Failed to send network information to the device. 6308 Timeout. 6310/6311 Invalid device. Authorization failed. 6309/6312/6313/6314 Cannot connect the Bluetooth device. 6315/6316/6317/6318/6319/6320 The device cannot connect to WiFi due to incorrect WiFi password, SSID, or IP is not assigned to the device. For all the errors above, please try to pair the device again in Bluetooth pairing mode.
General errors
400/403 App error This is an error concerned about the application you are using. Please contact your customer support with your eWeLink account to get further assistance. 401/402 Login expired Please log in again. 406/407 Account error You are not allowed to handle this device with this account or this device belongs to another account. Please submit feedback in eWeLink app with your device ID and eWeLink account if you are the owner of the device. 500 Server error This error code indicates that there is a server error now. Please submit feedback in eWeLink app and wait for eWeLink to email you about the recovery time.
