The Power-on State feature allows you to choose what state your device should return to after power is restored, such as after a power outage or after the device has been physically powered off.
Note: This feature is only supported by certain devices.
Power-on State Options
Depending on your device, you may see the following options:
- ON: The device will automatically turn on when power is restored.
- OFF: The device will remain off when power is restored.
- Last state: The device will return to the same state it was in before power was interrupted.
How to Set the Power-on State
- Open the Device Settings page in the eWeLink app.
- Tap Power-on State.
- Select ON, OFF, or Last state, depending on your preference.
- Tap Save.
Note: If the device is shared with you by another user, you may not be able to change its Power-on State setting.
If you have any other questions, feel free to reach out to us at support@ewelink.zendesk.com. To help us assist you more efficiently, please include as much detail as possible about the issue, along with any relevant screenshots.
