Question
Why do I need to add a Zigbee gateway before I can add a Zigbee device?
Answer
Zigbee devices cannot connect directly to your phone or Wi-Fi network. They communicate using the Zigbee protocol, while phones and routers generally use other network protocols such as Wi-Fi.
To add and control a Zigbee device in the eWeLink app, you first need a compatible Zigbee gateway.
The Zigbee gateway acts as a bridge between your Zigbee devices and the eWeLink app. It allows the app to communicate with and manage your Zigbee devices.
A Zigbee gateway can also:
- Centrally manage multiple Zigbee devices.
- Maintain communication between Zigbee devices within the local Zigbee network.
- Support certain local device interactions even when the internet connection is unavailable, depending on the gateway and device features.
Therefore, you need to add a compatible Zigbee gateway before pairing Zigbee devices with the eWeLink app.
If you have any other questions, feel free to reach out to us at support@ewelink.zendesk.com. To help us assist you more efficiently, please include as much detail as possible about the issue, along with any relevant screenshots.
